Cloudy headlights
Old Mar 2, 2011 | 11:24 AM
jdahlen24's Avatar
Default Cloudy headlights
My driver side casing is cloudy, but I can't tell if it's the outer casing or the inner small projector lens. It's really noticeable now that I've got HID's in there. The passenger side, which has a newer casing(thanks to hitting a dear) is much brighter than the drivers side.
What's the most popular method of polishing the casing to try to remove the cloudy look? Do those polishing ***** that you attach to a cordless drill work?
Old Mar 2, 2011 | 11:51 AM
Sohcvtec1995's Avatar
Mequires has akit for like 20 bucks, comes with drill attachment and a bottle of the lens cleaner/plastiX. works great and comes with enough to to multiple cars
Old Mar 2, 2011 | 12:22 PM
jdahlen24's Avatar
Thanks, I'll give it a try. Hopefully it's not the inner projector lens that's the problem. The outer casing doesn't seem all that cloudy, though.
Old Mar 2, 2011 | 08:37 PM
A4 2000's Avatar
I'm an expert at this lol. Get yourself some 2000 grit wet-sanding paper and some of this stuff. You need to wet-sand the headlight until you remove all the outer coating that's on there until you reach the pure plastic surface. Dry the plastic and apply this polish with the special cloth that it comes with in a swirl motion until the sanding scratches magically disappear. Polish off the polish the same way with a clean dry cloth and your headlight will look like they are almost new. Your arms will get tired, but the results will be worth it.
Old Mar 3, 2011 | 09:55 AM
jdahlen24's Avatar
Thanks A4_2000! I think I'll try your method first.
Old Mar 3, 2011 | 08:46 PM
A4 2000's Avatar
No problem. Oh, and when wet sanding, you should move the sandpaper in one direction (side to side is best) so the tiny scratch marks are easier to polish off.
beastmode24
Apr 4, 2012 09:52 PM
xTTx
May 7, 2008 07:22 PM
mattinaz
Nov 6, 2007 02:04 AM
SloRide
Sep 18, 2006 03:26 AM
nabujam
Sep 8, 2006 02:59 AM
