cluster info?? NEED HELP OR LINKS
Old Aug 19, 2009 | 06:45 PM
1.8TNYC's Avatar
Default cluster info?? NEED HELP OR LINKS
i have a 1998 1.8t and some of the lights in my cluster is not working and the screen so i took out the cluster and notice that the left and right plugs fits fine but the middle plug is different. so im guessing that the previous owner had changed the cluster do to the junkyard writing on the bottom part.
anyways i found a few other clusters for sale and wanted to know how would i be able to put the right miles back on the cluster??
heres a pic of the cluster thats in the car now
Attached Thumbnails cluster info?? NEED HELP OR LINKS-audia4instrumentcluster.jpg
Old Aug 19, 2009 | 07:51 PM
ghost6303's Avatar
you are correct, that cluster with the screen is from a 1999.5 or newer car. but if your current cluster is from a junkyard, how do you know how many miles the car originally had on it? you would probably just be replacing one wrong odometer with another. there are places online you can pay to burn in the correct mileage (if you know what that is), but its expensive and im not sure if they can do it to used gauge clusters, i think it can only be done on new zero mile clusters.
Old Aug 19, 2009 | 08:50 PM
1.8TNYC's Avatar
a seller told me that the cluster resets from the ecu??
Old Aug 19, 2009 | 08:59 PM
Midniteoyl's Avatar
No.. its in the cluster from what I understand.
Old Aug 20, 2009 | 12:14 AM
1.8TNYC's Avatar
blackedoutaudi (3:23 PM 8-19-2009): yea,but it reads the miles off of the ecu not the cluster...
thats the qoute from the seller
Old Aug 20, 2009 | 02:23 AM
Midniteoyl's Avatar
We need auditech to chime in..
Old Aug 20, 2009 | 05:23 PM
rcheing's Avatar
To my knowledge the cluster has an odometer module in the cluster itself, I have never heard of the ECU feeding the miles to the cluster. That's why when people get new clusters with new odometer modules they can set what mileage they had before, otherwise, they wouldn't be given this option since the ECU would have automatically sent the correct mileage.
Old Aug 20, 2009 | 08:52 PM
ghost6303's Avatar
this is false. the cluster stores the mileage. if faking the odometer reading was as easy as swapping out ECU's that wouldnt make much sense would it? people can swap ECUs as much as they want, the mileage stays the same.
Old Aug 24, 2009 | 09:07 PM
1.8TNYC's Avatar
thanks on the help members
Old Aug 29, 2009 | 09:20 PM
1.8TNYC's Avatar
stop spamming with all your bullshit
lowroad
Jun 19, 2009 11:39 PM
Jackball42
Aug 4, 2008 06:17 PM
JK35
Apr 8, 2008 04:10 PM
