Clutch problems
Old Apr 23, 2014 | 08:34 AM
86f250xlt's Avatar
96 a4 Quattro
I have no clue exactly what happened! But while driving to work this morning my clutch pedal after being pushed suddenly stuck to the floor but with a little more effort than before, it would still go into gear after I stopped and pulled the clutch pedal up! it built pressure again. but my clutch is slipping like it was sprayed with clutch fluid
Old Apr 23, 2014 | 08:59 PM
86f250xlt's Avatar
Any ideas?
Old Apr 23, 2014 | 09:12 PM
Pbcrazy's Avatar
Sounds like the slave cylinder, Could also be the master but I believe the master cylinder on these cars is a combined brake/clutch so if your brakes are fine, your master is fine (might be wrong on this, forgot where I read it). More likely the slave
Old Apr 23, 2014 | 10:16 PM
86f250xlt's Avatar
Brakes are still working just fine... Car barely made it home though last hill on my road I didn't think it was gonna make it up it!
Looked into the parts at my local auto parts stores and I'm not willing to pay almost 400 for just the clutch I found a stage 3 racing clutch on eBay for only $209 plus shipping
Old Apr 24, 2014 | 09:09 AM
redline380's Avatar
Legal Moderator
No, it isn't the same.
OP, I highly doubt you have a clutch problem, but unless you want to buy a new clutch, I would driving the car. What is happening is the clutch is being stopped from completely engaging. You need to look at the whole system, from maste cylinder, to the line, to the slave cylinder, to the fork. You could have a clutch problem, but I don't think so right now
Old Apr 24, 2014 | 11:14 AM
86f250xlt's Avatar
I have another vehicle I only drove it home... But I would like to drive my car it's a lot better on gas than my other vehicle which is where my username came from 86 f250 ext cab 4x4 diesel
I planned on starting into it tonight!....
Is there an inspection cover for the clutch/flywheel so I can look at it?
Old Apr 24, 2014 | 11:24 AM
redline380's Avatar
Legal Moderator
no, the tranny needs to be removed to access the clutch.
Old Apr 25, 2014 | 04:32 PM
86f250xlt's Avatar
There is no cover to even be able to look at the clutch? That sucks....
phila19146
B8 Models
Dec 22, 2010 02:35 PM
pullacowonaski
Mar 27, 2009 12:00 PM
s4raf88
Jun 16, 2007 01:41 PM
SamJamaica
Jun 13, 2005 02:07 AM
