Codes!!! Help!!
Old May 27, 2010 | 05:43 PM
Baby Kito's Avatar
Default Codes!!! Help!!
17843
17955
17964
18010
18014
17521
17525
17536
17633
17697
17829
17833
mods in sig! HELP!
Old May 27, 2010 | 06:29 PM
Baby Kito's Avatar
17521- Bank1-Sensor1 Internal Resistance too High
17525- O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
17536- Long Term Fuel Trim mult.,Bank1 System too Lean
17633- Cyl.1-Fuel Inj.Circ. Short to Ground
17634- Cyl.2-Fuel Inj.Circ. Short to Ground
17635- Cyl.3-Fuel Inj.Circ. Short to Ground
17636- Cyl.4-Fuel Inj.Circ. Short to Ground
17697- Turbocharger bypass valve short to ground
17829- Sec.Air Inj.Valve Circ Short to Ground
17833- Tank Vent.Valve Short to Ground
17863- Exhaust gas temperature sensor 1 range/performance
17955- Boost Pressure Contr.Valve Short to Ground
17964- Charge Pressure Contr. Negative Deviation
18010- Power Supply (B+) Terminal 30 Low Voltage
18014- Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction (dont worry about the last one. I just need my abs module redone)
Like i said i have a giac chip, new plugs and a samco inlet pipe. Im thinking my 02 sensor is wigging everything out. once my codes are cleared i have boost but once its on i lose all boost and limp mode is on. car runs fine just no boost. any ideas guys??? I really want to get my baby fixed
Old May 27, 2010 | 10:27 PM
Baby Kito's Avatar
anything for me?
Old May 27, 2010 | 10:33 PM
chocalotstarfish's Avatar
Super Moderator
Well just by looking at it, it seem there is a massive short somewhere... Whats the one thing they all have in common?
Edit: After doing some reading that ABS code is a code for an electrical short in the ABS is it possible that short is causing other items to crap? Have you tried disconnecting the abs altogether and see what happens? I mean it's a shot in the dark...
Old May 27, 2010 | 11:50 PM
Baby Kito's Avatar
The abs thing just means my abs module is toast. known this for a few months, ha. where going to disconnect it and get it rebuilt in a week or so. What im thinking is it's the 02 sensor. Is it a possibility that the 02 sensor is making the car run leaner causing all my injectors to short and cause all the other problems including boost loss?
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
