Coilpack keeps poping off
Old May 12, 2010 | 08:39 AM
mikekey's Avatar
Default Coilpack keeps poping off
For the past couple of days now, I've had a coil pack keep popping off, and I have no idea why. Anyone have any suggestions on what might be causing this and how to prevent it, before something bad happens.
Old May 12, 2010 | 08:47 AM
dragonrage's Avatar
Some people just have this problem. You can get brackets to keep them down... Probably easy to make some yourself as well.
Old May 12, 2010 | 05:32 PM
jmgrande's Avatar
First check to see if your coil pack connector is broken. If so my brother did a good write up on replacement.
https://www.audiforums.com/forum/sho...ight=coil+pack
Like dragonrage mentioned, some people get brackets for them or make them. ECS Tuning carries them, just make sure you get the correct ones for your engine code. I believe you have an AWM like mine, so any of these should work.
http://www.ecstuning.com/Audi-B5_A4-..._Pack_Harness/
Old May 12, 2010 | 05:44 PM
dragonrage's Avatar
You can just get something like this (actually, much shorter is fine), cut it down and use longer bolts. Use jam nuts or threadlocker or spacers if the bolts you get don't tighten down enough without wanting to put too much pressure.
http://www.homedepot.com/Tools-Hardw...atalogId=10053
It wouldn't look as good, but $45? Come on, ECS.
Old May 12, 2010 | 05:50 PM
chocalotstarfish's Avatar
Super Moderator
Or maybe something like this if you are really strapped for cash!
And custom colors to pimp out your ride!
Old May 12, 2010 | 06:15 PM
mikekey's Avatar
I'm not strapped for cash, and not trying to be a dick about it. But I saw the ones on ECS earlier today and they do look pretty. I just rolled 100K and thought I might as well grab some plugs at the same time.
I do have the AWM engine code, so all of those will work.
sb301
Apr 13, 2012 12:25 PM
murdox
Sep 6, 2011 08:14 AM
turbofan
B7 Models
May 4, 2010 06:31 PM
ericcota2003
Apr 5, 2009 02:32 PM
pa4ul
Feb 16, 2008 11:11 PM
