Control arms worn - what options
Old Jun 2, 2010 | 10:03 AM
vtraudt's Avatar
Default Control arms worn - what options
The front end makes a clonking noise, and I can move the wheels quite a bit.
What is the best way to go? Car has 140,000 mls on it.
- get bushing set (PU, 10pieces, FCP Groton, $285)
http://www.fcpgroton.com/product-exe...ategory_id/181
- get control arm kit aftermarket (12 pc, FCP Groton, $305)
- get S4 upgrade control arm kit aftermarket (ditto above, but S4 upgrade)
- get 4 piece control arm kit upgrade S4 (FCP Groton, $75)
Other sources and suggestion?
How does the Groton stuff compare with OEM and other sources?
Please post your experience and links.
Is it possible to just replace the bushing, or have the arms to be replaced as well?
Can someone post 'how to' links to do the work?
Old Jun 2, 2010 | 02:54 PM
ImTheDevil's Avatar
Get the 12-piece kit, either A4 or S4. If the bushings are shot the ball joints are probably on the way out too. Replace everything and be done with it. Check AudiWorld.com for a DIY. That's the most likely place to find it.
jamm220
Jul 17, 2012 01:58 PM
jdahlen24
Aug 25, 2011 09:50 PM
jdahlen24
Aug 25, 2011 03:05 PM
audiboy31790
Aug 20, 2008 11:07 PM
VolcanicBlackA4
Jul 18, 2005 05:42 PM
