Coolant Temp sending unit. how many?
Old Feb 13, 2012 | 06:24 PM
slfalco's Avatar
Default Coolant Temp sending unit. how many?
97 A4 2.8, dash temp gauge reading stone cold all the time... I searched and read about the sensor to replace, but does this one sensor feed the ECU also? I would think a broken sensor would trip a CEL, wouldn't it? Heater works OK after engine is warmed up... Just wondering if ECU gets coolant temp from a different sensor than the one feeding the gauge....
Old Feb 13, 2012 | 11:37 PM
bshusted's Avatar
I have a similar issue. There is only one physical sensor. Within the one, there are two different thermistors. One to drive the ECU and the other for the dash. If the sensor is in the same location on your 12v as my 30v, it is in a coolant pipe on the passenger side of the engine next to the firewall, just below the throttle body.
http://www.audiworld.com/tech/eng54.shtml
It's really not that bad to replace. I replaced mine in less than 15 min, though it did not fix the problem. I assume that since I still have the same symptoms, the thermostat must be the problem. As the ECT was easier to replace, I elected to start there.
Old Feb 13, 2012 | 11:48 PM
DOC_DEPALMA's Avatar
He's right, that's where it is. Be careful not to break the shitty corrugated plastic tube coming out of the valve cover = $$.
Old Feb 14, 2012 | 01:09 PM
slfalco's Avatar
Thanks, been there and done that with that stupid plastic breather hose, it had broken before and caused a CEL... replaced with heater hose.. I'll give the sensor a shot, seems inexpensive enough...
Old Feb 15, 2012 | 12:47 AM
bmoore98A4's Avatar
true dat. and be careful of the stupid flimsy plastic horseshoe clip thing that holds the sensor in. broke mine lolz. its a dollar or two at the stealership
rsborn
Jan 16, 2012 06:32 PM
kiellish
Oct 11, 2009 10:44 PM
A4 Mike
Sep 3, 2009 07:52 PM
typ 44
Jan 31, 2008 06:39 PM
slocumnb
Mar 22, 2006 11:45 AM
