couple of problems please help
Old 01-27-2012, 04:00 AM
brokena4's Avatar
Default couple of problems please help
my a4 1.8t is getting hot on the freeway ...fluids are good no leaks .. also it is a 5 speed and when im at 3000 rpms in 5th im only going about 70 and at 2200 rpms im going 50 whats with that ? is that normal i think thats why the car is geting hot to keep up on the freeway im at 3500rpms the engine oil gadge is reading 215 i dont know if thats why its getting hot or not but its getting 1 notch past half on the stock gadge if i drop of the rpms it comes back down ..this cant be right the gearing seams wierd
Old 01-27-2012, 08:05 AM
chocalotstarfish's Avatar
Super Moderator
3.5k for 70mph sounds about right. Over heating issues can be due to a fan not kicking on poor coolant, or a valve not opening...
Old 01-27-2012, 09:41 AM
ImTheDevil's Avatar
If your temp gauge is good but the oil temp gauge is high you may have a bad oil cooler or sludge blocking flow to the cooler. The RPM at those speeds is right.
Old 01-27-2012, 12:54 PM
bmoore98A4's Avatar
isnt 215 kinda high??? I sit between 185 and 200.
ar15600rr
04-07-2012 06:52 AM
onepoint8tee
07-26-2010 01:09 AM
Figgy1682
07-04-2009 12:54 PM
TT_GUY
11-13-2008 06:25 AM
Jayhova804
01-30-2007 06:53 AM
Quick Reply: couple of problems please help
