Couple of questions about dv's and pulleys....
Old Apr 11, 2008 | 05:53 PM
ChadS89's Avatar
Default Couple of questions about dv's and pulleys....
- What spring am i supposed to use??? i got Forge 007p's... it came with a set of springs in em, as well as 2 other sets
also, im about to do a timing belt.....
- has anyone put light weight pulleys on???I was thinking of doing this since i would have everything out of the way... but wasnt sure...
- has anyone used ecs's ultimate or ultimate plus timing belt kit??? Good... bad?? Thoughts
Thanks,
Old Apr 11, 2008 | 06:12 PM
ImTheDevil's Avatar
Default RE: Couple of questions about dv's and pulleys....
No idea on the DV springs, but from what I've read here, the lightweight pulleys really don't do anything for your car, and the concensus seems to be that it's money better spent elsewhere. As for the t-belt kit, it's got everything you'll need, which is nice - one-stop shopping is the best choice in this case.
Old Apr 11, 2008 | 06:22 PM
ChadS89's Avatar
yea i was just wondering if it was worth it since its all gonna be apart... or if i should go for tubbing... or any other options...
Old Apr 12, 2008 | 09:16 AM
bolob5's Avatar
Getthe ECS crank pulley for the TB job.
Old Apr 13, 2008 | 06:56 PM
ChadS89's Avatar
can you notice the differance?
Old Apr 14, 2008 | 02:44 PM
feerocknok's Avatar
It should have the identical effects as losing weight off your flywheel. You lose almost 3 lbs with the new pulley; that's pretty considerable.
ECS is still running that sale that makes the pulley 70 bucks with the purchase of a timing belt kit; I'd definitely take advantage of that if I was already doing the timing belt.
Old Apr 14, 2008 | 05:29 PM
chaos92287's Avatar
use the green spring and dont get a lightweight pulley. no noticeable gains (maybe 2hp at the crank, but you can't even feel that) and it can potentionally cause problems
Old Jul 21, 2008 | 09:53 PM
ChadS89's Avatar
COOL THANKS
Red_sapphire89
Jan 5, 2012 09:28 AM
ChadS89
Apr 11, 2008 01:11 AM
ChadS89
Mar 27, 2007 03:38 AM
neilsa4
Aug 10, 2006 11:01 PM
16w/A4
Jul 12, 2006 04:02 AM
