crank stuck
Old Mar 19, 2013 | 08:05 PM
Boober's Avatar
Default crank stuck
I'm rebuilding the head, it's off the car but the crank wont turn by hand anymore. It used to just fine until the battery died. I think it might be the starter was engaged when the battery died and is stuck in that position.
Any ideas on how to free it up?
Thanks.
Old Mar 20, 2013 | 06:54 PM
jeckel20003's Avatar
The starter shouldn't be engaged. It uses a solenoid to push the starter gear out and engage. So if it doesn't have any power going to it it shouldn't be engaged.
Old Mar 21, 2013 | 05:46 PM
Mike-2ptzero's Avatar
Might as well pull the starter just to see if the motor turns without it in there. If it still wont turn you know something else is causing the issue.
Trigger200
B7 Models
Apr 27, 2015 11:58 PM
Boober
Jan 20, 2013 02:05 PM
fibersnet
Aug 3, 2007 11:50 PM
fryguy
Jun 24, 2007 11:54 PM
