Creaking noise from drivers side front control arm
Old Mar 22, 2010 | 02:24 PM
cyguy2003's Avatar
Question Creaking noise from drivers side front control arm
So I foolishly went to the dealership to diagnose a creaking noise in my front end on my 2001 A4. They said I needed a new strut on the drivers side!
I didn't think it was a strut so under futher invesitgation by myself, it appears to be from a linkage attached to a switch/sensor on the drivers' front lower control arm. What is this switch called? I tried searching in the forums with a few different keywords and wasn't having much luck finding a diagram
I was wondering if it was possible this had something to do with the HID headlight leveling? It is amazing that something this small could make as much noise as it does. I sprayed the joints with silicone spray and it helped somewhat.
Has anyone else had any issues similar to this?
Thanks in advance! I wasn't sure if this was more appropriate here or in the suspension forum.
Last edited by cyguy2003; Mar 22, 2010 at 02:26 PM. Reason: Added Lower front control arm
Old Mar 22, 2010 | 02:36 PM
ImTheDevil's Avatar
That's exactly what that is - tge headlight leveling module. Still, I'd take a good look at your bushings and ball joints just to be sure your control arms aren't starting to wear out.
Old Mar 22, 2010 | 03:03 PM
cyguy2003's Avatar
Thanks for the confirmation. I wonder if there are any replaceable parts on that leveling module or if I can take it apart and clean them? With my luck, it's probably a $200 Audi part.
Old Mar 22, 2010 | 03:43 PM
CCA4's Avatar
Thats the only kind there are
HallLAD
B7 Models
Mar 12, 2014 02:10 PM
smoovmusicdj
Feb 20, 2008 12:34 PM
xqae
Jan 3, 2008 01:16 PM
xqae
Jan 2, 2008 01:41 PM
yellowa4
Sep 14, 2005 04:45 AM
