creaking sound from back wheels
Old Apr 26, 2011 | 02:33 AM
A4 2000's Avatar
Default creaking sound from back wheels
Whenever I sit in the car or get out, there's this creaking metal on metal contact noise that comes from the back wheels which makes the car sound like an old beat up truck. Could this be coming from the rear bearings or something? I thought it was the springs at first, but the sound seems to be coming from the center of the wheel or behind it? Anyone have or had this problem?
Old Apr 26, 2011 | 02:44 AM
rawdney88's Avatar
i actually have the same problem. mine is a FWD as well. i thought it was the springs too. some insight on this would be great
Old Apr 26, 2011 | 07:27 AM
ImTheDevil's Avatar
I'm willing to bet it is broken rear springs for both of you. They break a lot on these cars (if you have stock springs), right at the bottom. Get in there and look - you'll see about the last 4" of the spring, the section flat on the perch, broken. It's happened to every A4 driver here that I know. It's God's way of telling you to lower your car.
Old Apr 26, 2011 | 08:55 AM
krazzz's Avatar
Agreed, he can't give you a clearer sign than that!!
Old Apr 26, 2011 | 10:28 AM
rcheing's Avatar
Jeremy's absolutely right. My left rear spring is broken right at the bottom and makes a creaking sound. The only way to see mine is to lift it up and see it. I will be replacing those once I get my Bilsteins with HR springs.
Old Apr 26, 2011 | 12:20 PM
MetalMan's Avatar
Is your parking brake engaged when you do this? Mine creaks when I don't pull it tight enough. If it is engaged, just disengage it and then try.
Looks like A4 2000 might be lowered already.
Old Apr 26, 2011 | 12:49 PM
A4 2000's Avatar
Yep. I have Eibach pro kit springs. I really don't think its the springs.
fast euro
Apr 9, 2011 05:25 PM
daigoro
Sep 15, 2009 02:57 PM
evanlau
B8 Models
9
Sep 7, 2009 08:38 PM
jk944s
Oct 27, 2008 12:56 PM
JewbinTT
Oct 13, 2006 03:50 AM
