Cricket noise under the hood
Old Apr 6, 2013 | 05:15 PM
hartsoe1's Avatar
Default Cricket noise under the hood
I've changed my serpentine tensioner and my AC belt tensioner and I still have chirping noises coming from under the hood. so, I guess its my power steering pump. (timing belt kit done within the last 40,000 miles) Should I just ride this pump out until obvious failure? Other than a puddle of PS fluid under the car, what symptoms will indicate it is failing? Will it leave me on the side of the road, or can I still drive it home after failure?
Old Apr 6, 2013 | 06:36 PM
86f250xlt's Avatar
Idea of if it is the power steering pump... Pinch of the low pressure hose, and if it is the power steering pump it will make the noises worse
Old Apr 7, 2013 | 05:19 PM
Dallas09's Avatar
You could try bleeding the power steering system, basically you turn the wheel from lock to lock a bunch of times. Failing fan bearings for the HVAC system will make a similar noise FYI.
Old Apr 7, 2013 | 06:14 PM
hartsoe1's Avatar
I have the HVAC squeak in the cabin on an intermittent basis, also. LOL
Old Apr 8, 2013 | 01:31 PM
hartsoe1's Avatar
I'm bumping this for the question:
what is the downside of just driving it until the PS fails?
audipixie
Dec 26, 2012 05:09 PM
nutter97
Aug 18, 2010 12:07 AM
phitau09
Nov 17, 2008 11:02 AM
motegiman07
Aug 21, 2008 09:11 AM
wezal
May 8, 2007 04:24 AM
