cruise control: is there a dash indicator light ?? (i swapped modules)
Old Jun 16, 2014 | 11:53 PM
normal's Avatar
Default cruise control: is there a dash indicator light ?? (i swapped modules)
Hi - so my cruise hasn't worked in years. After lots of reading about both (possible) switch issues and module failures, I decided to buy a used module off ebay that was listed as compatible for my 1998 (.5) b5 audi a4 Q 2.8. The used module was much smaller than my existing/original module, but pin out diagram and plug size looked the same, so I plugged it in. cruise works perfect with this used/smaller module
Should there be a cruise indicator on dash?: Ithink I recall that a dash indicator used to come on when cruise was engaged (with original module when it worked), but there are no lights now. I'm more that happy just to have working cruise, but am curious if there was a light and if perhaps this 'smaller module' just doesn't have the light functionality part.
I didn't write down the module numbers, but could post them up later if needed. Would appreciate feedback
Old Jun 17, 2014 | 11:28 AM
A4TurboGuy's Avatar
Mine doesn't have a cruise indicator lamp.
Old Jun 17, 2014 | 12:01 PM
Mad Cow's Avatar
I could've sworn that my old '99.5 cluster had a cruise control indicator, but my new '00 one doesn't. I wouldn't worry about it.
Old Jun 17, 2014 | 12:15 PM
MetalMan's Avatar
Neither my '98.5 (with LCD and non-LCD clusters) nor 2001.5 have an indicator for cruise control. I can't recall having seen an input wire to the cluster from the CC module (based on wiring schematics).
Old Jun 17, 2014 | 02:42 PM
mtroxel's Avatar
The 99.5 in my signature doesn't have a light, neither did my dear departed 96 A4 Q.
Old Jun 17, 2014 | 02:57 PM
normal's Avatar
thanks for all of the replies, I'm so happy it works and won't think/wonder about indicator anymore!
Old Jun 17, 2014 | 03:00 PM
normal's Avatar
For those that may be in a similar situation, I would highly recommend trying this route. I got a new/used module for super cheap on ebay.
NOTE: you can drop/tilt/lower the glove box without any tools, reach in and unplug existing module and then plug in the new one (just let it dangle for a test), and take for test drive. from opening box from mail to test drive was less than 10 minutes.
should have done it long ago.
Old Jun 17, 2014 | 05:59 PM
Mad Cow's Avatar
Also if you're handy with a soldering iron you can fix the majority of them by reflowing the solder around the capacitors, terminals, and other through-hole mounted things. No need for a new one, especially since it'll also fail the same way eventually.
Old Jun 17, 2014 | 06:26 PM
MetalMan's Avatar
Exactly what fixed the CC in my '98.5. Went through all of the diagnostics with the stalk switch and checking components in the engine bay, only for it to be this easy of a fix. It was just too bad I did it a couple months after a 2,000 mile road trip!
CAD Stewie
Dec 13, 2010 03:19 PM
5th_year_senior
Nov 8, 2009 01:11 PM
jonsaudi
Aug 13, 2007 08:09 PM
rpavkov
May 4, 2007 01:59 PM
