Degreasing the engine bay...???
Old Apr 26, 2008 | 07:22 AM
K1196A's Avatar
Default Degreasing the engine bay...???
I know some of you guys keep your cars wicked clean which i know means you clean the engine up to. i need to clean my engine and want to know which components you guys are protecting with foil or plastic to keep them safe and dry.
in advance, thanks for your advice....
Old Apr 26, 2008 | 07:31 AM
ImTheDevil's Avatar
Default RE: Degreasing the engine bay...???
I don't wrap or cover anything. I use simple green degreaser, rags, toothbrushes, and in some cases Q-tips to get the grease and grime off. You probably don't want to spray your engine bay with the hose, if that's what you're thinking. Take the time to use a spray bottle of degreaser and a lot of elbow grease. When you're done, you can spray the entire engine with 100% silicone spray or use CD2 Engine Bright to make everything gleam.
Old Apr 26, 2008 | 10:55 AM
mr.cAp's Avatar
+1
DO NOT SPRAY THE HOSE ON YOUR ENGINE BAY!
to much electrical stuff, in fact the was a post a day os two ago of a guy who f-ed up his TB by doing somthing like that, Simple green is the **** though
Old Apr 26, 2008 | 11:23 AM
K1196A's Avatar
OK -- no hose action then. Yeah Simple Green is hardcore. When I was in the army I routinely used that **** to clean my machinegun and it worked better than even carb cleaner! I'm always amazed how strong the fumes are for a "natural" product.
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
