driving 100 miles on a bad powersteering pump
Old Feb 20, 2009 | 03:50 AM
pearlescent's Avatar
ok thats good to know, I drove about 25 miles right after the install and the "whining" sound did seem to get a LITTLE better.... i guess ill just give it some time. Thanks.
Old Feb 21, 2009 | 02:39 PM
Okay I've driven about 150 miles on the new pump, and the whining sound is still there.... Is something wrong?
Old Feb 22, 2009 | 12:25 AM
Tweaked's Avatar
Was it a new pump or used?
Old Feb 22, 2009 | 07:54 PM
It was used pump overhauled/rebuilt by a company called Atsco. I bought it from Autozone for $185, they charged me a core price of $65 as well. I have now driven over 250 miles on the pump, same "whining" sound and it is more intense as the wheel is turned. However, The steering remains responsive and works great.
Thanks,
Matt
Old Feb 23, 2009 | 08:44 PM
could I have possibly done something wrong with the install?
Old Feb 23, 2009 | 09:46 PM
hiwords's Avatar
wow you're lucky it didn't explode on you. are you leaking ps fluid right now? i don't think you could have messed up the install, it's pretty straight forward. try using some lucas. the thicker fluid might help it
Old Feb 24, 2009 | 12:19 AM
The sound can't be normal, and the fluid is bubbling like crazy in the res, I do not think i am leaking at all...
Old Feb 24, 2009 | 04:12 PM
  #18
Tweaked's Avatar
Sounds like there is still air in it. Keep bleeding. Back and forth with the wheel, top off the reservoir. Do this with the cap off.
Remove the suction line from the rack to the pump. Put it in a bucket. Have a friend pour new ps fluid into the reservoir while the car runs. Please note: Power Steering fluid is EXTREMELY FLAMMABLE! Do not spill it! This is not a recommended method, but can be used if necessary.
Also, check your hose clamps. If they are loose, the pump will suck air.
alsabti
Aug 14, 2010 01:25 PM
Willrwilli
Jun 2, 2009 12:21 AM
joeforza
Dec 22, 2007 11:34 PM
aberfitch82
Oct 24, 2007 02:59 PM
pyrotechnique
Sep 18, 2006 09:01 PM
