DTC Question
Old Jan 28, 2009 | 02:03 PM
ObnoxiousDrunk's Avatar
Default DTC Question
Just pulled a P0158. O2 Sensor Circuit High Voltage Bank 2 Sensor 2...It reads at 1.275 Volts while the others are pulling around .480. Just wondering if anyone would know what caused it and if I definitely need to get this fixed asap.
Old Jan 28, 2009 | 02:20 PM
onepoint8tee's Avatar
Probably just a weak ground in the wiring for that sensor. You can replace the sensor or live with it. It wont affect your mpg or performance.
Old Jan 28, 2009 | 03:07 PM
Tweaked's Avatar
Swap the post-cat O2 sensor to the opposite cat and erase the DTCs. If the DTC returns, but follows the O2 sensor to the opposite bank, replace the sensor.
Old Jan 28, 2009 | 04:48 PM
flyromeo3's Avatar
check if the sensor has a broken wire on it. Mine did which suck'd and a bish to remove.
B1 S2.
Old Jan 31, 2009 | 05:24 AM
Well it's throwing the codes again so I guess I'm looking at replacing bank2 sensor2. If anyone has replaced this O2 sensor, how big a pain in the *** is it to swap out?
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
