EBAY Vag Com
Old Apr 7, 2009 | 09:14 AM
JimyYeags's Avatar
Default EBAY Vag Com
Hello all-
I have a 98 A4 non turbo... I was thinking about getting a Vag Com Cable off Ebay... Will I be able to reset the check engine or abs lights? I understand if there is something truely wrong that the lights will come back on shortly after resetting... What EXACTLY will I need.. anyone have expereince with this.
Old Apr 7, 2009 | 10:06 AM
turbo kraut's Avatar
Tech Guru
i have the ebay cable... you can get that and d/l the program from ross-tech, but when you want/need to erase the code, you will need to do a search(run) for fault codes, then go to the specific section if you find a miss-fire running vag, then you will need to go into the engine section and re-ren for that part... and clear from there....
you can't clear codes like if you have the ross-tech cable...... 1 extra step, but works the "same" and alot cheaper than $200
Old Apr 7, 2009 | 10:32 AM
2fast4u66's Avatar
yup, get the $20 ebay cable, get the 409 free software. Once you read the codes, fix them then they wont come back :P
Old Apr 7, 2009 | 12:35 PM
JimyYeags's Avatar
Thanks guys so that should work... So what cable EACTLY do I need?
Will this one work for me once again 98 audi a4 non turbo quat
http://cgi.ebay.com/ebaymotors/USB-V...motiveQ5fTools
Old Apr 7, 2009 | 01:08 PM
Tech Guru
thats the one i got
Old Apr 7, 2009 | 02:34 PM
audiA4gm's Avatar
Originally Posted by turbo kraut
thats the one i got
I believe I have the same one as well, and when I plugged it into my car it prompted me for an authentic Ross-tech registered product...so the cord works fine, but I need to bypass the registration, or do you know of an available Password/Registration key so I can use the cord?
Old Apr 7, 2009 | 07:16 PM
JimyYeags's Avatar
Found this nice write up... for those of you that know how to do this what other tips do you have I just ordered mine.
http://www.audizine.com/forum/showthread.php?t=158766
Old Apr 13, 2009 | 08:57 PM
JimyYeags's Avatar
Can you give me a step by step? I got the cable tonight and got the vag com software... havent gotten to plug in to the a4 yet. my airbag and brake lights are on... how do i run it to get the codes and how do i clear then?
Old Apr 14, 2009 | 02:12 AM
A4speed's Avatar
so you can clear the codes if you go to the control module in the upper left and select engine? i just barely got the cable and scanned the codes with 409.1 but haven't figured out exactly how to clear them.
Old Apr 14, 2009 | 05:04 AM
Veegard's Avatar
You should check google for a .bat script which in combination with some genuine licencefiles will make the program work in fullmode all the time. You will need to use torrentsites to download a cracked version, then make the scripts yourself (or find them on the net).
I haven't found an option to take off the service lights yet, anyone else have? I use standard FTDI chipset cable and vagcom 409. Was able to do stuff like throttle adjustment on it, but don't know how to reset service lights!
