Elec Fan Owners !!!
WHo has an elec fan in place of the poopy mechanical fan clutch? If so where di you tap? I was just gonna run a constant to a relay and just put it in a 12v switched ignition or put it on a switch. Other ideas?
I bought a Hayden thermostatic relay controller to go with my e-fan. This has an input for switched ignition (ran this wire into the cabin through the ECU box), a full-time +12V, a ground, and a wire that I tapped into the AC compressor clutch (so the E-fan will turn on whenever the AC is on). This unit also has a temperature probe which is meant to go between fins on the radiator, so that whenever the radiator hits a certain temperature, the fan will turn on. And that temperature setting is adjustable
The fan comes on after maybe 20sec. of idling at stoplights (depending on ambient temperature) and turns off shortly after pulling away from the stoplight. It works rather well!
link to said control ?
If you have it linked to turn on when the ac fan does, it is just the same to wire it in series/ parallel with the a/c fan already in the bay? just to bypass all the extra wiring of another relay and a temp control for it.
johnebusch
Aug 3, 2005 08:39 PM
