Electrical failure
Old Oct 14, 2016 | 02:19 PM
Russ Pederson's Avatar
Default Electrical failure
Hi again....i have a 2000 audi a4 quattro 1.8t and when i got off work this morning i drove home and everything worked fine with the car. I went out 20 min. Later to go to the store and when i started the car the windsheild wipers, the turn signals and the heater blower didnt work. The hazard lights work but the turn signals dont...is there a fuse or relay that could control all those things?
Old Oct 14, 2016 | 03:29 PM
elduderino200's Avatar
Not work at all? Or you heard a sound but didn't see a light on the dash? My dash has some bad connections so the arrow light often doesn't up but the (more important) outside 'actual' turn signal does.
In any event, have you checked appropriate fuses?
https://s-media-cache-ak0.pinimg.com...2a261dfbaf.jpg
Its becoming rainy season where I live so water intrusion is always a possibility that can cause annoying electrical issues. Make sure to check your ECU/housing.
Old Oct 14, 2016 | 04:38 PM
I checked the fuses and they all look good...and ya the signals dont work at all.
Old Oct 14, 2016 | 08:35 PM
Crap those were all the ideas I had. Hopefully someone else can help
Old Oct 15, 2016 | 06:35 AM
Someone told me that it might be the ignition switch. Has anyone had similar problems when there ignition switch was failing? I priced one at napa for $26 so im jus gonna replace it and see what happens..
Old Oct 15, 2016 | 11:33 AM
A4TurboGuy's Avatar
That sounds a lot like a relay issue. I can't remember if all of those are powered by the same relay, but you should definitely look into it.
If a new ignition switch is quick and easy, you might as well do that too (regardless).
G/L
Old Oct 15, 2016 | 09:21 PM
Ok i replaced the ignition switch and it solved nothing. The problems are still there. Does anyone know where the ignition relay is located on a 2000 a4 quattro 1.8t? I cant seem to find a reference for one.
Old Oct 16, 2016 | 01:55 PM
A4TurboGuy's Avatar
Every relay diagram you will find will say something different. It drove me crazy. You just have to Google the name "X" Relay" and go to "Images" and find as many relay panels as you can that look like yours and also show the same layout, then take a shot at it.
That's the best advice I can give.
G/L
Old Oct 19, 2016 | 12:42 PM
Ok...three words for u guys...LOAD REDUCTION RELAY...if you ever come across this problem the fix is gonna be either the ignition switch or the load reduction relay. Cost was $29 from the dealer and solved the problem.
Old Oct 19, 2016 | 03:50 PM
awesome. cheap/quick fixes are the best
rcollins2867
B8 Models
Apr 26, 2016 08:32 AM
zombiekiller0331
Jul 15, 2013 09:46 PM
0fframp
Apr 29, 2004 01:16 AM
0fframp
Mar 9, 2004 02:13 PM
