Engine getting sick
Old Mar 14, 2012 | 04:57 PM
meloman's Avatar
Default Engine getting sick
So I just passed 140k and am trying to figure out what maintenance I should do, especially because I'm starting my BT build this summer.
But my main reason for bringing this up is because my car sounds unhealthy... not as in theres a knocking or anything but it just sounds like its in pain when I get above 3500 rpms. Dont know why this could be, it doesn't have that nice deep growl to it anymore, it almost sounds "dry". Sorry for such a terrible explanation but its the best I can do.
My oil changes are up to date, I'm not low on oil, my spark plugs and maf are good, coolant is fresh and full. No I do know that my cam chain tensioner is making a little bit of noise and could be replaced but I highly doubt that has much to do with whats going on.
Any insight?
Old Mar 14, 2012 | 05:02 PM
M5S5's Avatar
Tech Certified
Maybe the engine mounts are getting worn.
Old Mar 14, 2012 | 06:35 PM
MetalMan's Avatar
Primary and (maybe) secondary oxygen sensor(s)?
I just searched in your timeline, looking for an indication that you might be running a test pipe in place of your cat. Didn't find anything. Are you still running the stock/original cat?
EDIT: Nevermind about the cat, I see that you did indeed get a test pipe at one point.
Old Mar 14, 2012 | 06:54 PM
cincyTT's Avatar
I'm make believe
And what does the boost gauge say? Please tell me you have one?
Old Mar 15, 2012 | 12:37 AM
meloman's Avatar
One of the first things I did! Forgot to mention that both my vacuum and boost readings are normal running on a giac chipped ecu. And I do have a test pipe and I replaced the secondary o2 sensor with a brand new one when I put my test pipe in.
Old Mar 15, 2012 | 08:55 AM
CCA4's Avatar
Any chance you could get a vid/sound clip of what you're hearing? It's always tough to diagnose engine noise over the web but a sound clip would definitely help
Old Mar 15, 2012 | 10:54 AM
MetalMan's Avatar
How about the primary O2 sensor? This is the one that controls fueling, so if it's in bad/old shape then so could your air-to-fuel ratio.
Old Mar 15, 2012 | 12:06 PM
meloman's Avatar
I can try to get up a video, not sure how well it will come out.
And I didnt even think about the primary o2. Wish I had an afr gauge so bad..
Old Mar 15, 2012 | 10:09 PM
ImTheDevil's Avatar
Have you scanned it? If not, if you have time, I should be able to meet up with you this weekend and can scan it for you. Shoot me a text tomorrow.
stevec
Mar 17, 2012 01:18 AM
Tourbo24
Apr 16, 2010 12:36 AM
Emilgevor
Mar 24, 2009 11:10 AM
