engine missfire new stage 1
Old Mar 3, 2012 | 12:34 AM
repsol68's Avatar
Default engine missfire new stage 1
hi guys well this is my problem . i just install the ecu stage 1 . and the problem is after 10 pounds the engine start multiple missfire below 10 pounds no problem. engine light came on and code is multiple missfire in all cylinders . mi car is a 2000 audi a4 atw . thanks
Old Mar 3, 2012 | 03:31 AM
sb301's Avatar
Where did u get the tune? Take it there ASAP. And have them see wassup with it.
Old Mar 3, 2012 | 08:37 AM
ImTheDevil's Avatar
Sounds like you didn't gap the plugs down to .028" (stock is .032"). Did you upgrade the DV also?
Old Mar 3, 2012 | 09:10 AM
saharanate's Avatar
agreed spark is not enough or not enough or too much fuel! pull the plugs after u run it see what they look like? stink like gas or built up carbon?
Old Mar 3, 2012 | 09:42 AM
repsol68's Avatar
Which spark plugs you recomend to install on the car ?
Old Mar 3, 2012 | 10:54 AM
ImTheDevil's Avatar
You're fine with stock plugs. Get a new set and gap them properly.
Old Mar 3, 2012 | 10:58 AM
FASTER's Avatar
Tech Slut
Devil is most likely right on. But its not uncommon for coils to crap out right after chipping for the first time.
Old Mar 3, 2012 | 09:14 PM
repsol68's Avatar
Thanks for the help it was the gap on the plugs it was way open i set up at .28 now is a diferent car .
MoonDog
Oct 21, 2009 07:11 PM
waddlecaudle
Aug 18, 2009 11:20 PM
ezrider1978
Apr 10, 2009 11:16 AM
red_dawg_02
Apr 4, 2007 03:14 AM
damir21
Oct 6, 2006 12:36 AM
