engine swap from passat to an o1 a4 ???
Old Mar 7, 2010 | 11:31 AM
scout78's Avatar
Default engine swap from passat to an o1 a4 ???
I have an 01 a4 1.8t engine code awm mtrans it needs a motor i found one out of an 01 passat same engine code and mtrans. does anyone know if these engines are the same and compatible to swap? would there be any difference in compression ratio between the non turbo passat and the turbo a4? any help with this would be much appreciated thanks!
Old Mar 7, 2010 | 04:24 PM
FASTER's Avatar
Tech Slut
direct swap, exactly the same engine.
Old Mar 7, 2010 | 04:42 PM
Andrew149's Avatar
go for it!!! you should be good
Old Mar 7, 2010 | 04:59 PM
pyropenguin's Avatar
Non turbo passat?
Old Mar 7, 2010 | 05:17 PM
Andrew149's Avatar
all the passats that were 4 had a turbo the only 1.8 ive seen is on a jetta
Old Mar 7, 2010 | 09:37 PM
Not in Europe.
Old Mar 8, 2010 | 01:18 PM
Andrew149's Avatar
oh that sucks for them
Old Mar 8, 2010 | 03:18 PM
hiwords's Avatar
in china they had 2.6 A4s lol
65Ford
Sep 4, 2014 11:26 PM
Goingallout
Jan 11, 2012 05:02 PM
mccutch2u
Apr 3, 2008 04:22 PM
diego7
Dec 18, 2007 10:13 PM
