engine swap question
Old Nov 22, 2010 | 09:30 PM
twoeightquattro's Avatar
it has burned about 3 quarts in the last 1900 miles... :/
Old Nov 23, 2010 | 02:14 PM
briesa4's Avatar
Have you been able to pin point a leak point? And have you done anything like your valve cover gaskets, change your oil pan, ect.?
Old Nov 23, 2010 | 07:06 PM
Tweaked's Avatar
I would assume you're seeing smoke out the tailpipe with that kind of loss due to burning.
If there's no smoke, look for a leak. It's a lot cheaper and easier to fix what you have. Swaps are huge projects, especially if it's you're first time. Bolting up isn't the issue... it's the ECU, harness, clutch setup, and immobilizer that are a PITA to work with when swapping.
But if you want a recommended swap, upgrade to a newer 3.0 V6 for an easy setup.
bmoore98A4
Jun 3, 2011 04:03 PM
sjcarton
Jul 26, 2010 12:42 PM
JKEITH81
Aug 29, 2007 04:26 PM
SILVER_B5S4
Feb 6, 2006 07:51 PM
Ocnaj
Jan 25, 2005 09:45 AM
