Flashing Oil Light, Dead, Still has spark/fuel/comp???
Wife was drivin the audi the other day, oil light came on then started flashing. The tach stuck at 3k and the engine just stalled. I've checked everything I can think of. It seems to have spark? has fuel 'the plugs are wet after trying to start for awhile'. Compression seems fine. Timming belt is intact and seems fine? I dont get why it wont start. I've checked turbo to I dont get it........
I have a freeware version vag-com and these are the codes I pulled
P1602-Low Voltage
P0422-Cat/02 'old, this has been goin on post incident'
P1137-System to rich
P1555-Charge pressure "to much boost"
P1338-Crank position sensor/speed sensor?
P1548-Boost pressure control valve
I'm thinkin ICM or somethin, Any idea's or ways to rule stuff out would be great
P1602-Low Voltage
I cant clear codes because I only have the freeware version for my vag-com, Is there any way else to tell before just throwin money at it? Could that code mean anything else? The discriptions are just what I found online 'hoping they are correct haha'...
Sounds good i'll give it a try. Everytime I tried last time it says I need to register the software which cost's another $100 on the website threw vds-lite. Is there anyother software that doesn't require $$$$ ?
You may be downloading the wrong one - I downloaded USB409 as shareware a few years ago and had no fees at all. I have the full version now and it rocks but the shareware works great for most things you'll need.
So I reset the codes 'figured out how to do it with my software'. And i'm still getting the cam sensor failure. My question is will that make the car not start? I've been looking at other forums and it seems that nobody can make up their mind if it will make a difference if it's bad. Other than crap fuel mileage etc etc. I don't wanna blow $80 if its not the root of the problem?
The ECU reconciles the cam sensor's positioning info with that of the crank sensor. If it doesn't get readingsfrom both, indicating their positions, it doesn't trust that there will be no damage if the car runs, so it refuses to start.
So I had a crankshaft sensor code pop up after I installed the cam sensor. So I bought a new crank sensor and put it in. AND NOTHING... This car is makin me pull my hair out lol.. Now it's not throwing any engine codes any help would be awesome...
Stephenwhite990
Jul 3, 2013 02:25 PM
tonygump
May 10, 2011 12:41 AM
jjock
Sep 10, 2009 08:23 PM
