Flashing Oil Light, Dead, Still has spark/fuel/comp???
Old Aug 9, 2011 | 12:48 AM
boostedZJH's Avatar
Default Flashing Oil Light, Dead, Still has spark/fuel/comp???
Wife was drivin the audi the other day, oil light came on then started flashing. The tach stuck at 3k and the engine just stalled. I've checked everything I can think of. It seems to have spark? has fuel 'the plugs are wet after trying to start for awhile'. Compression seems fine. Timming belt is intact and seems fine? I dont get why it wont start. I've checked turbo to I dont get it........
I have a freeware version vag-com and these are the codes I pulled
P1602-Low Voltage
P0422-Cat/02 'old, this has been goin on post incident'
P1137-System to rich
P1555-Charge pressure "to much boost"
P1338-Crank position sensor/speed sensor?
P1548-Boost pressure control valve
I'm thinkin ICM or somethin, Any idea's or ways to rule stuff out would be great
Old Aug 9, 2011 | 07:06 AM
ImTheDevil's Avatar
P1338 is the one that matters. Clear the codes and see what comes back. If that comes back, it's the cause of your no start. The car won't start or run with a bad crank position sensor.
Old Aug 9, 2011 | 10:43 PM
boostedZJH's Avatar
I cant clear codes because I only have the freeware version for my vag-com, Is there any way else to tell before just throwin money at it? Could that code mean anything else? The discriptions are just what I found online 'hoping they are correct haha'...
Old Aug 10, 2011 | 06:19 AM
ImTheDevil's Avatar
I looked up P1338, and it's a cam sensor failure - that'll also keep you from starting. Shareware vagcom clears codes easily - try it again, and see what comes back.
Old Aug 10, 2011 | 10:56 PM
boostedZJH's Avatar
Sounds good i'll give it a try. Everytime I tried last time it says I need to register the software which cost's another $100 on the website threw vds-lite. Is there anyother software that doesn't require $$$$ ?
Old Aug 11, 2011 | 07:08 AM
ImTheDevil's Avatar
You may be downloading the wrong one - I downloaded USB409 as shareware a few years ago and had no fees at all. I have the full version now and it rocks but the shareware works great for most things you'll need.
Old Aug 22, 2011 | 11:58 PM
boostedZJH's Avatar
Default Tried it again
So I reset the codes 'figured out how to do it with my software'. And i'm still getting the cam sensor failure. My question is will that make the car not start? I've been looking at other forums and it seems that nobody can make up their mind if it will make a difference if it's bad. Other than crap fuel mileage etc etc. I don't wanna blow $80 if its not the root of the problem?
Old Aug 23, 2011 | 12:57 PM
ImTheDevil's Avatar
The ECU reconciles the cam sensor's positioning info with that of the crank sensor. If it doesn't get readingsfrom both, indicating their positions, it doesn't trust that there will be no damage if the car runs, so it refuses to start.
Old Sep 2, 2011 | 03:16 AM
boostedZJH's Avatar
Default ????
So i bought a new camshaft sensor, installed, and nothing changed. It still just turns over without even trying to start? Any other ideas on what i could try next?
Old Sep 13, 2011 | 01:18 AM
boostedZJH's Avatar
Default GRRRRR haha..
So I had a crankshaft sensor code pop up after I installed the cam sensor. So I bought a new crank sensor and put it in. AND NOTHING... This car is makin me pull my hair out lol.. Now it's not throwing any engine codes any help would be awesome...
Stephenwhite990
Jul 3, 2013 02:25 PM
abdelqadert54
Audi Q7
May 3, 2013 12:21 AM
blanthony
Mar 25, 2006 01:18 PM
