FMIC boost sensor
total size is 27x6x2.5
I got the 2.5" pipe kit, but my final design is just using two 90 degree pipes, and the rest are pieces of straight pipe and rubber hose. I'll make a new post about the whole install when I'm finished.
As far as the MAP sensor, I did the tap and dye method, then used a make-a-gasket sealant. That should work right?
[IMG]local://upfiles/47894/C25B78E5084141CFB9F196F9DFDD6162.jpg[/IMG]
Leifer, do you mean using JB weld instead of make-a-gasket would have been safer? I did drill three holes:
[IMG]local://upfiles/47894/52CE1AD330FF472F9DFD4FC30B5B5841.jpg[/IMG]
boosTT 225
Jun 19, 2008 12:47 PM
