found this not connected...
Old Mar 13, 2011 | 01:23 PM
wryfly's Avatar
Default found this not connected...
Here is a hose leading into the air filter....but as you can see...it's not connected!
How am I supposed to get my big mits down there to push it back in? Does the wheel liner need to come off, or hit it from below?
Thanks!
Attached Thumbnails found this not connected...-dsci0001.jpg   found this not connected...-dsci0003.jpg
Old Mar 13, 2011 | 01:41 PM
Jc61990's Avatar
might be for the SAI... not too sure tho, my car doesnt have one
Old Mar 13, 2011 | 01:52 PM
Mad Cow's Avatar
Seems like an SAI hose, but it looks broken and not disconnected. You can just take out the airbox to give you enough room.
Old Mar 13, 2011 | 01:57 PM
Msnickbroderick's Avatar
Actual WIZARD
That would be you SAI pumps intake tube. Its unmetered air, so you can just leave it as is, or pull the airbox out and fix it
Old Mar 13, 2011 | 02:20 PM
wryfly's Avatar
thanks guys.......ya i just pulled the air box and noticed it was broken. Does this NEED to be attached or can i live without?
Old Mar 13, 2011 | 03:37 PM
evelluser's Avatar
Read the post above yours OP
Old Mar 15, 2011 | 10:18 PM
Mad Cow's Avatar
Just tape it up tight and you'll be fine.
Old Mar 16, 2011 | 07:51 AM
CCA4's Avatar
Yeah buying a replacement for that would be a waste of money:
http://www.ecstuning.com/Audi-B5_A4-...ission/ES6606/
IMO, it needs to be fixed because that crack is letting unfiltered, unmetered air into your intake. I recommend electrical tape. Very high-tech
Old Mar 16, 2011 | 08:09 AM
ImTheDevil's Avatar
Then I must have one of the most advanced, space-age PCV breather tubes on the forum since I have at least 3 feet of electrical tape sealing various breaks in mine
Old Mar 16, 2011 | 08:21 AM
wryfly's Avatar
holy crap.....$90 bucks for that thing?? You can buy a lot of electrical tape for that!
Chatis
Nov 27, 2013 03:39 PM
B5boostin
Jun 11, 2012 02:38 PM
jhanson25
Apr 30, 2010 11:49 PM
rplets15
Aug 9, 2009 06:45 PM
Brandon318
Aug 13, 2006 04:13 AM
