Front End Pop felt in steering wheel when Turning under load, replaced tie rod
Old Sep 2, 2012 | 08:22 PM
Dallas09's Avatar
Unhappy Front End Pop felt in steering wheel when Turning under load, replaced tie rod
Hey everybody,
I have a front end pop that have just come up. This happens most often and dramatically when making a very sharp turn at lower speeds (e.g. turning into a parking lot). The pop can be felt in the steering wheel and sounds like it is coming closer to the driver side than the passenger side. I just replaced the entire Tie Rod on the driver side and the problem persists. Any thoughts?? Thanks much.
Old Sep 2, 2012 | 09:15 PM
cnigro1279's Avatar
Originally Posted by Dallas09
Hey everybody,
Ive been having the same problem and am thinking its my lower control arms. Tie rods are tight on my car but Im getting a bump or pop in the wheel when I turn far to the right. Seems to happen more at lower speeds like pulling into a parking spot.
Old Sep 2, 2012 | 10:08 PM
redline380's Avatar
Legal Moderator
jack the car up on that side and try to move to wheel up and down and side to side. it could pretty much any ball joint, including those in the control arms, wheel bearing or cv shaft. youll have to check to play in all of those
Old Sep 3, 2012 | 01:50 PM
Dallas09's Avatar
I was thinking the first symptom for ball joints is usually a squeak but I guess Im wrong on that. Now Im wondering if I should go ahead and just replace all of the CAs again. They were last replaced 80,000 miles ago.
Old Sep 5, 2012 | 10:24 AM
Dozanti's Avatar
Cv axle(s)
Old Sep 5, 2012 | 01:45 PM
ImTheDevil's Avatar
Agreed with Dozanti (although it could be anything in the wheel well) simply because my LF outer CV is worn out, and makes the same noise.
parlayin
Dec 30, 2010 05:23 AM
california_avant
Aug 7, 2010 07:38 AM
Audi S4 Turbo
Apr 22, 2010 10:42 PM
syncrasy
Aug 18, 2008 02:54 PM
