Front end sway and shake
Old Sep 14, 2011 | 09:48 PM
workoncars's Avatar
Default Front end sway and shake
1996 A4, 18'' Forte, Yokahamas, Front end starts shaking at about 55 but smooths out at some speeds for short periods and then shakes again. Steering also wanders from left to right. Pulls to the right and then to the left and then tracks straight. I replaced all of the control arms, tie rods, and balanced the tires. The shop said the tires were out of round so I put on new tires, but still have the same results. What is left?? Steering feels tight just pulls from side to side and shakes like hell.
Old Sep 14, 2011 | 11:41 PM
airguard350's Avatar
Tech Guru
Wheel bearings?
Old Sep 15, 2011 | 07:53 AM
jonbonesjones's Avatar
Moderator
u never mentioned an alignment....
Old Sep 15, 2011 | 09:14 AM
ImTheDevil's Avatar
Inner CV joints cause wandering and vibration at speed when they're worn out.
Old Sep 15, 2011 | 11:34 AM
Tech Guru
Ah, yeah I forgot about that... Just like you said people usually do. Lol
Old Sep 15, 2011 | 09:25 PM
workoncars's Avatar
I think you might have something with the cv joints. I did replace one axle but the other looks original with 180K on it. The wheel bearings seem tight and smooth. thanks for the pointers.
Old Sep 18, 2011 | 09:37 PM
workoncars's Avatar
The stick on weights fell of one of the wheels when I pulled them off to replace the control arms. I found them on the floor today. I bet after a balance it will be ok.
Old Sep 19, 2011 | 11:07 AM
raudi28's Avatar
could also be a bent rim. if they couldnt balance the other tires and new ones still did it, would make sence.
bigpapascott
Sep 24, 2014 11:13 AM
jzstuggie
Jul 14, 2013 09:41 PM
M3Armand
Mar 19, 2013 10:51 AM
IPStevieB
Jul 29, 2011 12:28 PM
B5luver
Dec 18, 2007 12:42 AM
