front fog light
Old Feb 9, 2010 | 01:03 PM
Nightstalker14's Avatar
Exclamation front fog light
i just bought a 2001 audi a4 1.8t i noticed the front fog lights not work so i found that the fuse was blown so i replaced and noticed the smoke coming from the passeneger side fog light. so i disconnected the fuse then looked at the fog like and noticed an hid kit followed the wiring and it was all melted does any one have a wiring diagram for the fog lights and an easy fix for me.
Old Feb 9, 2010 | 01:19 PM
Andrew149's Avatar
sounds like the hids are bad
Old Feb 9, 2010 | 03:44 PM
hiwords's Avatar
you have to turn the headlights on in order to turn the fog lights on. the headlight switch triggers a relay on the fog light button and then you can finally turn on the fogs. the actual colored wires remain to be know because i've tried to do an independent fog light mod using the wires and none of the wires seem to work. maybe the relay more tricky than i thought it was. also the wiring diagram in the haynes manual is wrong
Old Feb 10, 2010 | 08:42 AM
ya i thinks so too. but i need to replace the wires since that melted, i just need a wiring diagram to follow but cant find one.
Old Feb 10, 2010 | 10:30 AM
Andrew149's Avatar
can you just trace the old wires? and just do it how it was orginally?
Mischief
Oct 11, 2010 01:41 PM
tketke
Nov 2, 2008 07:01 PM
Asianicestyles
Apr 13, 2008 04:11 PM
2002QuattroRoadster
Jan 11, 2008 10:42 AM
M2WILLIAMS
Nov 19, 2005 06:50 PM
