Fuel gauge and directionals
Old May 15, 2010 | 08:05 PM
Ghostrider II's Avatar
Default Fuel gauge and directionals
Ok, here is the deal. Two weeks ago, I ran the tank down to way past E if you must, insert the Seinfeld reference here, but it was not intentional. Filled tank up, no worries needle shot to F. Today, I had just under half a tank (between half and a quarter), and I had to do a 180 mile drive round trip, so I decided to top it off. Filled tank, but needle read 3/4ths. Is this a dreaded sender shitting the bed? How difficult is it to remove and replace?
Next question, however I think I know the answer. Directionals and emergency flashers do not work- flasher unit? How to access to remove and replace? It is behind the emergency flashers switch, no?
Thanks!
Old May 15, 2010 | 08:22 PM
Tourbo24's Avatar
there is a little wire on the fuel level sending unit that might of ripped in half and needs to be replaced. it is a very easy fix and there was a DIY for this floating around somewhere
Old May 15, 2010 | 09:29 PM
A4 2000's Avatar
Replace the relay switch that's connected to the emergency flasher button and you'll be good. As for the gas, wait a little to see what happens first. The same thing happened to me and it started working again on its own. Sometimes the float just gets stuck and might go back to normal on it's own.
mnorm757
B7 Models
May 11, 2011 04:00 PM
cdpoppert
Nov 17, 2007 03:22 PM
southcoast
Mar 19, 2007 10:38 PM
LuckyCharmsUXZ
Feb 9, 2007 01:36 PM
rccks96
Jan 21, 2007 12:49 AM
