Fuel Problems
Old Aug 12, 2011 | 10:37 PM
ImTheDevil's Avatar
Another quick way to confirm or eliminate the relay as the cause of the problem is to unplug it and put a jumper wire from the constant 12v (battery) terminal slot to the switched leg slot and see if it'll fire. In this way you're hard-driving the pump without using the relay and you can see if the symptoms persist.
Old Aug 12, 2011 | 10:38 PM
awddrftr's Avatar
And what are thw injectors codes? All 4 of them? And yes the relay is good.
Old Aug 12, 2011 | 10:49 PM
ImTheDevil's Avatar
I could believe the injectors are throwing codes as a result of a bad relay or ignition switch. Basically if the ignition switch is messed up and not fully firing up the fueling system it's easy enough to believe the injectors aren't going to work. One additional check you could do is to verify (with a meter) that all four injectors are properly grounded.
Old Aug 13, 2011 | 06:42 PM
awddrftr's Avatar
GOOD NEWS and lame news. THe car started, it was the timing fuse my dad had moved to the vacant slot and the car started on the dial. the sucky news is. the car wants to die when ever i step on the gas. it will rev but then it will cut off and almost die.
Saturday,13,August,2011,17:46:04:49579
1 Fault Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-00 - -
Readiness: 0110 0101
Old Aug 14, 2011 | 05:20 PM
awddrftr's Avatar
Update* i cleared the code and retryed the Throttle Body Alignment and IT WORK! car runs fine. but i had installed a used fuel pump and took it for a test drive and then the car died on me. good thing i had a spare, now the car is working well. but fuel pump seems to be priming quite loud. maybe because i have my back seats down?
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
Tcomguy1
Aug 28, 2011 05:37 PM
mkearns140
Oct 19, 2007 07:46 PM
chadha
Apr 5, 2007 09:39 PM
