Hard shift when cold
Old Aug 13, 2013 | 04:14 PM
kingen502's Avatar
Default Hard shift when cold
The title pretty much says it all. If I let her warm up for a couple minutes she is fine. Just did the tranny fluid. Didn't get worse after i changed it just stayed the same. Lube express said no metal came out in the fluid and that the magnets where clean. Just wondering if this is a common problem or anything I can do to help my girl out. All opinions are appreciated. THX!!!
Old Aug 13, 2013 | 06:50 PM
mtroxel's Avatar
Don't know who Lube Express is, but I wonder if they know how to fill that trans? That fluid expands quite a bit as it gets warm, and that might account for the change. You might have been low before the change, and might still be low.
Old Aug 13, 2013 | 09:52 PM
Mad Cow's Avatar
There's a whole long procedure to fill these transmissions, if it's a random chain shop then chances are they didn't follow it properly.
Old Aug 13, 2013 | 10:58 PM
kingen502's Avatar
Any reference on this procedure. I'm sure I can find it but would be nice to get pointed in the right direction by someone who knows. Please and thank you. Also can I add fluid to the transmission myself. He said he did a very thorough flush.
Old Aug 14, 2013 | 07:59 AM
mtroxel's Avatar
I don't see it with a quick check, but you'll find it. ATF has to be between 35C and 45C. Run it through every gear with your foot on the brake and open the fill plug on the bottom of the trans. A little should fall out. If not, you're too low. You need a way to pump ATF up and into the trans, and you will get very messy.
Old Aug 14, 2013 | 08:26 AM
Mad Cow's Avatar
Basically this, but you have to repeat the whole put it through every gear and fill process at least 5 times in my experience before it's full. The annoying thing is the fill plug is at the bottom so unless you have a lift or pit you'll need to put it up on 4 jack stands
Old Aug 14, 2013 | 08:34 AM
mtroxel's Avatar
Yea it's very easy to underfill it. My 96 A4 sounded like a staw at the bottom of the glass when the trans was cold. I finally just ignored the proceedure and put more in till it sounded and shifted fine.
Old Aug 14, 2013 | 12:34 PM
kingen502's Avatar
Thanks guys! I think I'm just gonna take it back to the guy who did it and tell him what's going on. If it cost me $260 he should have at least done it right.
bex
Sep 10, 2010 06:26 AM
rjsanders81
Aug 20, 2010 07:04 PM
ledzepp2994
Dec 30, 2009 06:28 PM
jaz6
Dec 7, 2008 01:00 AM
CIA
May 31, 2008 01:48 AM
