head lights
Old Feb 16, 2010 | 05:07 PM
sunnyboy22's Avatar
Originally Posted by zakario
ok so I had to fix this issue last week and although there is a good diy on audiworld I'm going to help you out a bit. His directions for removing the wheel and trim pieces are perfect but you shouldn't remove the combi switch from the stalk. It just makes more work for you. once you get the steering wheel off (which takes maybe 3 minutes) it should look like this:
then you need to undo the medal plate with the four tiny allen screws and take the swith apart from the inside. it will look like this with everything removed except for the headlight contacts. (remember what it looked like so you can reassemble)
put your parts in a good place so you don't lose them
you will notice that your contacts both up top and on the bottom of the switch are covered in crap and will need to be cleaned and scratched with steel wool or sandpaper.
to clean the contacts just wrap some q-tips with steel wool like so
the copper contacts inside of the plastic housings will need to be cleaned and the springs that push them out will need to be stretched out
check to make sure nothing has melted and gotten in the away of the copper pieces. They must be able to leave the housing and make contact with what you cleaned back in the switch. If you had a bad connection due to the crap build up there is a chance the resistance caused enough heat to melt the plastic, and if it did, just sand it down.
*when you're reinstalling the metal plate that holds the switch internals in place you can adjust how much resistance the headlight lever gives you by tightening the 4 screws more or less. I went for a slightly tighter action on mine and it feels good every time i turn the lights on.
My pops and I got it done in 27 minutes so don't take it to a mechanic!
hope this is helpful
thank you to you all what a great help i love my b5 she runs like an audi!!
Old Mar 22, 2010 | 11:28 PM
McMeMan's Avatar
Ok SO I have about half this issue and it's beginning to worry me honestly. MY headlights work fine, the issue I noticed is that when I shut my car off and were to leave my lights on they go out when I turn the ignition off. which I believe is wrong they should remain on while the stick is in place right? and then even when I op[en my door I get no warning sounds telling m,e "hey the light switch is on", SO i'm confused at this point :|
Old Jun 2, 2010 | 11:14 PM
afil's Avatar
Zakario, thanks for the great post! I found the info on Audiworld, and combining that with your pictures makes this seem pretty easy.
Anyone know what size Torx bit I need to take off the steering weel?
Thanks
Old Jun 2, 2010 | 11:40 PM
ImTheDevil's Avatar
On my 99 3-spoke wheel it's a T55 for the big center nut under the airbag and a T30 for the airbag bolts on the back of the wheel.
konboy22
Jun 9, 2011 01:01 PM
Alicia
Jun 1, 2007 10:27 PM
mypreludeisred
Aug 9, 2006 11:08 PM
rickyzZ28
Feb 26, 2006 03:00 PM
BeefTaquito
Jan 25, 2005 01:41 AM
