headlight alignment
Old Apr 1, 2010 | 08:25 AM
SiIntegra's Avatar
Default headlight alignment
I have a 00 a4 Quattro with the H.I.D. lighting and the driver side light beam sits just enough lower than the passenger side to be annoying.
I have tried to adjust them, but anyway I adjust, its like it readjusts the projector. Is there a leveling sensor or something I can adjust?
I appreciate any help you guys/gals can offer.
Old Apr 1, 2010 | 08:48 AM
vgo's Avatar
vgo
I know factory HID headlights came with auto headlight leveller. I think there are screws mounted on top to adjust the lamps.
Old Apr 1, 2010 | 08:49 AM
CCA4's Avatar
They auto-adjust back because thats where they're supposed to be. The driver's side headlight cutoff should be stepped so as not to blind oncoming traffic
Old Apr 1, 2010 | 10:52 AM
tware4021's Avatar
not to thread jack but i have the depo one piece with HIDs and my headlights are aimed very low and the adjusters that the allen key thing doesnt move the headlights at all...i remember seeing a post Hiwords did about his and it said something about a levering switch for LHD and RHD...im thinking that ill have to take off my headlights to get to that levering switch so they will be aimed higher...does anyone have any input on this...sorry for stealing for thread
Old Apr 1, 2010 | 12:29 PM
CCA4's Avatar
ehhh as i recall that little flapper thing just controls the cutoff of the projectors. Its stepped one way for RHD, the other for LHD-again, so as not to blind oncoming traffic. Is it possible you've been adjusting the highbeams by mistake?
Old Apr 1, 2010 | 12:58 PM
dragonrage's Avatar
driver's side is supposed to be lower due to, as mentioned, the stepped cutoff.
Old Apr 1, 2010 | 01:31 PM
Dallas09's Avatar
I think you need to put the headlights in adjustment mode with a VAGCOM when you move the screw so they dont move back to where they were.
Old Apr 2, 2010 | 06:51 AM
SiIntegra's Avatar
Originally Posted by Dallas09
I think you need to put the headlights in adjustment mode with a VAGCOM when you move the screw so they don't move back to where they were.
I found an old post with the directions for setting the lights with the vagcom. Apparently that's what needs to be done. I just bought the cheap eBay wire and ross-tech 311.2. When i attempt to connect it sais something about baud failure re-attempting, and it will try a few times and continues to fail to connect.
I guess thats a whole different thread of questioning.
I did not know the headlight should be stepped like that. Every car that I have driven with h.i.d. lights have had a continuous cut off line. s2k, slk, infinity, even 3 series I remember being a clean line.
I dunno, I guess I don't have to worry about it if it will continue to re-set to that.
Old Apr 2, 2010 | 01:15 PM
Dallas09's Avatar
Try going to settings and readjusting the baud rate: i think they are either 10400, 9600, and 4800.. Can you connect to other modules?
Old Apr 3, 2010 | 08:52 AM
SiIntegra's Avatar
No, it will not allow me to connect to any module. It will connect to obdII, but then says this is an audi, seat, skoda, etc and please select a module.
Choch
B7 Models
Dec 31, 2013 12:57 PM
Mongo18
Sep 10, 2010 09:42 AM
Andrew149
Aug 21, 2009 06:21 PM
jamesj1k
B7 Models
Feb 21, 2008 08:40 PM
