HeLp. Audi will not start sometimes. A4 1.8 T 00'
Old Oct 20, 2010 | 01:33 PM
rhessballin@gmail.com's Avatar
Exclamation HeLp. Audi will not start sometimes. A4 1.8 T 00'
This is my problem. Sometimes when i go to start my car I press in the clutch and turn the key. Nothing happens no clicking, no cranking. So there is no signal getting to the starter. After about several tries it will eventually turn over. The starter is fine along with everything mechanical. Its got to be electrical. Cause there is no signal traveling to my starter.And when there is a signal it starts up like a charm. anyone know a quick diagnosis. Where to look? fuses? connections terminals? can this be clutch pedal related? I need to get this fixed but want to narrow it down. I also dont want my car not to start somewhere thus forcing me to get a tow.
Thanks alot
Rick
Old Oct 20, 2010 | 01:37 PM
kriptonik's Avatar
Moved to the appropriate section.
Old Oct 20, 2010 | 01:46 PM
colony777's Avatar
for the life of me i cant think of what its called. your ignition, where your key goes. they go out sometimes. also check your battery for corrosion
Old Oct 20, 2010 | 02:32 PM
CCA4's Avatar
lol its called the ignition switch
OP, after the one or two times you turn the key and nothing happens, when something eventually does happen, does it start right up?
Old Oct 20, 2010 | 02:39 PM
BrianJanice's Avatar
Originally Posted by rhessballin@gmail.com
...And when there is a signal it starts up like a charm.
...lol
Old Oct 20, 2010 | 02:53 PM
tware4021's Avatar
i know that theres a recall on the ignition switch if you call them and give them your VIN they will be able to tell you if its a recall or not
zslatcher
Oct 24, 2011 06:14 AM
mark944turbo
Oct 10, 2005 05:51 PM
