Help-can't remove climate control 2000 b5
Old Mar 29, 2013 | 03:22 PM
hartsoe1's Avatar
Default Help-can't remove climate control 2000 b5
I'm on a trek to change my Airbag Module. and I'm stuck trying to remove the climate control. I'm pulling on it but it ain't moving. I don't want to break it. Take a look at the picture and please respond. thanks
2000 a4 b5 atw
Note: I got the module out, and it was a K (the last letter of the part number being K) module. The one I ordered from a junk yard (had been in a rear end so it hasn't blown) came in as a G box, which was the original box back in the day. I had to grind off two guide tabs from the harness to make it fit. I had read somewhere about this. one controls side curtain air bags and I don't have them so that doesn't bother me. I just hope it will code up with my rig. Either way, I'm through with air bag modules.
Attached Thumbnails Help-can't remove climate control 2000 b5-2000-b5-a4-climate-control.jpg
Old Mar 29, 2013 | 03:41 PM
trev123's Avatar
try to take front off climate control unit to revel bolts held on with clips ashtray will have to comeout aswell make sure battery is disconnected trim by handbrake has to come off as well there may be two bolt above ashtray.
Old Mar 29, 2013 | 05:03 PM
hartsoe1's Avatar
There are two bolts above the ash tray, that can't be reached until the climate control is removed, but I think they hold the console in. I've disconnected the battery, the center console is out, trim around stick shift is out, and I don't think the face of the climate control comes off, I think the entire unit comes out. So, I'm still looking for the 'trick' to removing it as a complete unit. Thanks
Old Mar 29, 2013 | 05:36 PM
trev123's Avatar
i changed my air bag module about two years ago i will check tommorrow , you need to take out ashtray as well
Old Mar 29, 2013 | 05:49 PM
trev123's Avatar
i found a site that will help type[ audi a4 b5 articles in google, they puhed a flat screwdriver under the control unit to remove unit but check the site hope it helps
Old Mar 29, 2013 | 06:29 PM
hartsoe1's Avatar
I got the climate control out!! what a bitch. Cheers
Old Mar 29, 2013 | 09:25 PM
mtroxel's Avatar
Congrats. It is a bitch.
mrk3cobra
Jun 12, 2009 12:26 AM
rmorit01
Mar 26, 2009 08:30 PM
jb4uc
Mar 13, 2009 09:55 PM
S4rat
Aug 28, 2007 10:20 PM
hoonee46
Feb 14, 2005 02:55 PM
