Help with Deciphering Codes
Old Sep 26, 2010 | 05:56 PM
DEBlueHen's Avatar
Default Help with Deciphering Codes
My check engine light lit up recently. The codes are 17965, 17544, 16825, 16684, 16687, 16688.
I changed the valve check valve for purge system at the air box; replaced the crankshaft vent breather hose assemblies; pcv valve; unions and vacumn line.
It ran for 30 miles and I got another check engine light. Any idea what I should look at next? I could use some advise!
DEBlueHen
1999 A4 1.8T Quattro
Old Sep 26, 2010 | 10:19 PM
markymarc's Avatar
Check your MAF, it could cause your problem...disconnect it, if the maf is reading to high it will indicate a boost leak and cause your code.
If you have a registered VAGCOM log the engine measurement blocks that show airflow and boost during an acceleration run to see what is happening when the code is logged.
Old Sep 26, 2010 | 11:04 PM
pgf's Avatar
pgf
Try this link for codes and solutions
http://wiki.ross-tech.com/wiki/index.php/Main_Page
johnson90512
Apr 30, 2012 10:25 PM
Bayleybeee
Mar 15, 2012 04:25 PM
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
teecee
Jun 29, 2007 05:51 AM
