Help... Extended Problems
Old May 3, 2011 | 09:35 AM
browny355's Avatar
Default Help... Extended Problems
I have no boost on my car. It idles, but occasionally the RPMs jump around at idle and I won't be able to move. It's getting worse and more frequent as time goes on. Here's what I have replaced.
1) N75 valve
2) Diverter Valve
3) Pancake Valve
4) Cranckcase breather box
5) Some check valves
I don't believe I have a vacuum leak. There are no codes on the car when I ran them. I'm now at a loss. Any ideas?
Old May 3, 2011 | 10:59 AM
ImTheDevil's Avatar
Do a search for "boost leak checker" and make one to try out - that'll help you see if you have a leaking line. You can order vacuum line at www.siliconehose.com (3.5mm ID) and replace everything - never a bad idea especially on your 1.8T.
Old May 6, 2011 | 10:11 PM
browny355's Avatar
Thanks,
I built the boost checker and I'll see how it goes this weekend. I'm guessing I am going to find that my waste gate is broken in which case I think I need a new turbo. I'm thinking K04 if anyone can suggest where to get one. (ECS any good?)
Also there's a new problem. I seem to be losing 1 cylinder on the highway and occasionally when I'm stopped. Is this a coil thats starting to fail. No codes or CEL yet which is a pain. What are the chances this is bad gas?
Old May 8, 2011 | 03:44 PM
browny355's Avatar
It's really hard to move the arm that controls my waste gate. Is the diaphragm that controls this activated by vacuum or pressure?
Old May 8, 2011 | 05:03 PM
browny355's Avatar
Took the cat off. Plunger is gone on my waste gate. New turbo?
S4Bennett
May 25, 2010 07:31 AM
ou2mame
Dec 27, 2006 07:39 PM
ssss
Mar 20, 2005 10:12 PM
