help identifying a electrical plug S4 B5
Old Aug 14, 2011 | 09:16 PM
murraygeo's Avatar
Default help identifying a electrical plug S4 B5
I had a mechanic quit after he removed the engine for my 2001 s4 and I was left to re install the motor. I have the motor Back installed with New turbos and clutch, ect, But I have one electrical plug Remaining. I do not no where it goes It comes out of the main wiring harness at the back of the motor between the firewall. It has a black three pin connector with only 2 wires going into the connector tan and tan w red stripe. the center of the plug is purple and has the three pin all in a row. The wire has some heat shielding on the wire so I assume it runs near the turbo or exhaust. It comes out of the main harness with the two wire speed sensor that goes to the transmission. does any one know what this connector goes to? I can post a picture if need.
George Murray
Old Aug 15, 2011 | 02:17 PM
McGovs2.7TB5's Avatar
I'd post a pic. Unfortunately the S4 section here is kinda dead, post this up at Audizine.com along with the pic and I'm sure someone will know. The A4 guys here are great but you'd probably get better response on AZ for this one.
Old Aug 15, 2011 | 02:28 PM
ImTheDevil's Avatar
When we deep-sixed Emilgevor's afterrun coolant pump, IIRC there were two connectors right back there. One went to the pump and had an orange or pink insulator and the other had a purple one and plugged into something right at the back of and beneath the intake manifold. I don't know what it was, only that it was back there and slightly to the passenger side of center.
Old Aug 15, 2011 | 11:23 PM
murraygeo's Avatar
Default here is the picture of the conector
it is not the connector for the (speed sensor, O2 sensors, electric water pump, boost control, knock sensors, coolant level sensor,cam position sensor) they are all connected its the only one I don't know where it goes.
Attached Thumbnails help identifying a electrical plug S4 B5-photo-1-.jpg   help identifying a electrical plug S4 B5-photo-2-.jpg
Old Aug 16, 2011 | 10:06 PM
murraygeo's Avatar
i found the plug 2nd connector on transmission either speed sensor or back up light switch.
ee99ee
Oct 12, 2011 12:28 PM
max14
Mar 7, 2010 07:22 PM
hottubbrad
Dec 16, 2009 11:24 PM
dgallant
Sep 17, 2009 03:25 AM
werkwitdis
Jun 4, 2006 02:07 AM
