Help! No brake lights!
So I discovered that my brake lights are out, all three of them. Good fuse, I tried a different brake switch behind the pedal. Nothing. Relay maybe? I had just changed the brake light bulbs in the tail lights. Weird thing is, when i pulled the bulbs out, they were broken, like the glass at the base had broken but the filament was still in tact so they still lit up. Reverse lights, rear fogs, and directionals all work. Pass side running light is out and all break lights are out? What else could it be? Idk what else to do.
That makes sense. But what about the brake lights? Even the center one was out and I didn't touch it. What about the fuse box under the hood? I tried a relay and brake light switch from my 97. The relay was a different number(mine was 387 and the one I put in was 374) I'm starting to think I have a bad ground? Where would that be?
just pushed down and maybe corroded a little.
Unfortunately I'm not any help to you here; I have very little knowledge about working with electricals. However, it seems kind of odd to me that you would suggest that the contacts being bent wrong. If a couple of the lights were out, then that's one thing. But in this case, you are suggesting that ALL of his contacts suddenly decided to bend wrong at the same time.
Are you sure you replaced your bulbs with the correct ones? That's where I would look first. Check the bulbs you have in right now; are they burnt out? Are they broken? Either way, check the numbers and see if they are the right ones. I believe they should be 7528 and highmount should be 2825.
m5systems
Dec 19, 2006 06:30 AM
