HELP plastic in oil!
Old Mar 18, 2008 | 03:30 AM
freestyleski's Avatar
Default HELP plastic in oil!
Changing my pcv valve and that dam yellow dipstick holder thing that broke wile removing the intake manifold!!! A couple of crumb size pieces of plastic fell down the dip stick tube. What is the easiest way to get them out and do i need to at all. Thanks.
Old Mar 18, 2008 | 01:42 PM
Default RE: HELP plastic in oil!
22 hits! comon some input please.
Old Mar 18, 2008 | 01:44 PM
powersmokin's Avatar
you can try draining the oil threw a screen or filter to see if they come out if they don't they will never make it threw the filter in to the motor.
Old Mar 18, 2008 | 01:48 PM
acollicott's Avatar
are they stuck in the dip stick or did they fall all the way down? Idk if the oil filterwould catch it or not. If it was me I would start by draining my oil
Old Mar 18, 2008 | 01:51 PM
feerocknok's Avatar
The oil filter should catch it. That's what it's there for.
Old Mar 18, 2008 | 01:53 PM
thats fellas, the chips went all the way through the dip stick tube. My oil is empty now, i will run a bottle through to see if it comes out. thanks. didnt want to pukll the oil pan off.
Old Mar 18, 2008 | 08:45 PM
jiggleo's Avatar
you seriously think they're small enough to get past the pick-up screen of the oil pump? if they are then the oil filter will grab them otherwise they will just sit in your oil pan unless they do come out with an oil change at some point.
Old Mar 18, 2008 | 09:35 PM
vgo's Avatar
vgo
heres a crazy idea...flip your car upside down and shake it out.
i remember reading somewhere here or a link off of here about those things breaking off tho.
Old Mar 18, 2008 | 11:42 PM
B5 owns's Avatar
Mine is half way broken..
hcuniff
Jun 26, 2011 11:23 PM
shelbyturbo
Oct 8, 2008 09:12 PM
Indiepunk
Jan 13, 2008 01:58 PM
saintforlife
Jan 12, 2008 01:44 AM
nilla713
Feb 8, 2006 02:50 PM
