Quote:
ORIGINAL: hiwords
autozone has this stuff called like block sealer from stop leak. it basically makes your piston rings puffy so you don't burn as much oil.
This doesn't sound like something I'd put in my car. It sounds like a bad band-aid, like one made of scotch-tape and toilet paper.ORIGINAL: hiwords
If you're that concerned about what might have been done to your engine, do a compression test. Or even easier, a vacuum test.
Change the oil and filter. Get your hands on some BG M.O.A. (motor oil additive). Nothing else. It's the only one I've found that seems like it works.
