help with the washer fluid tank
Old Oct 25, 2008 | 12:53 PM
rplets15's Avatar
Default help with the washer fluid tank
ok so my washer fluid tank has a leak in it and i want to take it out so i can fix it and i took off the bolt that connects it to the car and it didnt move at all i assume its still connected somewhere but where and how do i get to it?
Old Oct 25, 2008 | 03:23 PM
410ThirtyValve's Avatar
I think they may be several bolts to it. I actually have the same problem and have to replace mine too, but I noticed when I did my tb job that the tank goes down quite a bit and has an odd shape. I remember it being secured in several different places. I am almost certain you must at least remove the lock carrier if I remember correctly (....that is, of course, assuming that you haven't already).
Old Oct 25, 2008 | 03:26 PM
CCA4's Avatar
i need to do that too, the pump for my headlight washers is burned out and leaks, i'm just too lazy to do it lol
Old Oct 26, 2008 | 01:43 PM
rhyab1's Avatar
Mine also leaks but only if I fill it up completely, so I just fill up half way...
mcanedo92588
Jul 1, 2013 11:27 PM
MartinCieslak1
Feb 25, 2011 07:51 AM
looking for an audi keyring
Mar 11, 2009 10:15 PM
Jusaywhat
Nov 10, 2008 11:49 AM
JohnnyBravoA4
Dec 11, 2006 01:31 AM
