washer fluid tank
Old Dec 10, 2006 | 11:33 PM
JohnnyBravoA4's Avatar
Default washer fluid tank
yea so my tank dosent want to hold any dam fluid before i rip the car apart is there any plug I should know about, or maybe a gasket around the sensor.. is this common i hate seeing that dam pisser in yellow on my center srean.. its driving me nuts, happend today, might have done something when i was fixing my endlinks maybe?
Old Dec 10, 2006 | 11:59 PM
onepoint8tee's Avatar
Default RE: washer fluid tank
There are 2 pumps that go into the resevoir which the casings of the pumps can deteriorate and leak. Take out the resevoir and check the 2 pump locations for leaks. Replace/fix. VERY common. Take out the drivers side wheel well and unbolt/unplug everything connected to it (the resevoir) and take out the resevoir- remove the pumps... Mine were leaking bad but the pumps still worked. So I just used some rubber cement/sealant, let it dry and wrapped them up in electrical tape and put everything back together. I did this about a year ago and so far so good. There is a DIY article for it floating around somewhere... Cant remember where.
Old Dec 11, 2006 | 12:35 AM
sweet.. just what i wanted to do, lol i just had that all apart.. dam..
Old Dec 11, 2006 | 01:03 AM
socal_A4's Avatar
Lol its funny that you mention that. Because Yesterday My fluid light came on so I stopped by the store and picked up some vac line and some windshield fluid. So today I remount my 007 back to its normal position because having it in reverse sucks big time. After I get done with that I was adding the fluid when I noticed that all of it was pouring out the bottom of the reservoir , so i got under my car again and took off the lower valence and the wheel well. I saw that it was coming from the pump at the bottom was leaking. So i syphened out the fluid so I could reuse it. dried it all up and put some water proof adhesive along with a rubber washer to prevent the leak. It takes 24 to cure all the way. But Ill let you know if it worked for me.
Old Dec 11, 2006 | 01:12 AM
so we did the same crap yesterday..lol thats great.. yea i am going to have to do something like that but first i have to spot the problem i just put a gallon of fluid in and watched it **** all over the ground.. then i got mad and played flag football..
Old Dec 11, 2006 | 01:31 AM
socal_A4's Avatar
yea when I saw it leaking I was like damn it Im going to have to clean that **** up, so i stuck my oil pan under there to catch some of it. Lucky I changed my oil the other day, and was fortunate to have cleaned it.
mcanedo92588
Jul 1, 2013 11:27 PM
MartinCieslak1
Feb 25, 2011 07:51 AM
looking for an audi keyring
Mar 11, 2009 10:15 PM
Jusaywhat
Nov 10, 2008 11:49 AM
rplets15
Oct 26, 2008 01:43 PM
