Hesitation problem
Old Jun 20, 2014 | 07:46 AM
regetsnave's Avatar
Default Hesitation problem
Hello i have a 99 audi a4 (awd) 1.8t all of the sudden car started to hesiate at around 4k rpm like it loses power then kicks right back in just started doing this yesterday...mods are garrett fmic garrett gt28rs turbo forged dv (15psi) and a euro dyne software i was thinking maybe the coil packs but thought i would ask...thank you
Old Jun 23, 2014 | 07:14 AM
GreenMachine22's Avatar
Im kind of having a similar problem, if not the same. Im runnin 10psi and just recently my car hesitates from 2-3k rpm. Ill hit on the gas around 2.5k rpm and the turbo will be putting out but the engine just kind of chokes and doesnt accelerate. Is this kind of what youre running into but at 4k rpm?
Old Jun 23, 2014 | 08:48 PM
george1546's Avatar
I'd maybe start with checking your fueling, easiest to check first would be the vacuum from the fuel pressure regulator to the intake manifold. See if the hose is in good shape and not split open or cracked losing pressure.
Old Jun 25, 2014 | 05:24 PM
regetsnave's Avatar
Angry
yes exactly
Old Jun 30, 2014 | 11:39 AM
The only hose that I found that may have an issue is the hose under the intake manifold. It looks wet (like its leaking possibly). Its a thicker hose but its really hard to see because the intake manifold is blocking the view. Cant trace where the hose goes/if the hose is sealed and in good condition.
Old Jun 30, 2014 | 12:10 PM
https://www.audiforums.com/forum/diy...-early-199692/
Actually found this on this forum. Might be the breather hose?
Think its the thicker hose on the left
Old Jun 30, 2014 | 12:53 PM
Found a crack in the breather hose. This is the best pic I could get of it.
ved
Feb 13, 2015 12:32 PM
Audiguy271
Nov 3, 2009 03:41 PM
Asianicestyles
Nov 5, 2008 10:02 PM
ttex
Aug 20, 2008 10:36 AM
s4duce
Oct 19, 2007 01:41 PM
