Hi, coil pack misfire issues, help...
Old Aug 7, 2012 | 02:08 AM
77Audi's Avatar
Default Hi, coil pack misfire issues, help...
First off, Hello, first post as a new member!
Car is 2001 A4 Quattro 2.8L.
Here is the issue: Starting with a new coil pack, it drives fine for a bit, then it will throw a code of misfire, the it will degrade into a shudder. No doubt dead cylinders and general crappy running makes its a PITA to think about driving.
Then warranty cycle repeats it's self...
Addressing this issue on my own, I've replaced:
* coolant temperature sensor (the one that always goes out)
* spark plugs
* coil pack several times
Wire set looks good, but I'm going to replace it anyway, as looks can be deceiving.
If anyone knows what else could be wrong, I appreciate the hand.
Thanks in advance!
Old Aug 7, 2012 | 10:37 AM
z28pete's Avatar
Are you getting a single cylinder misfire or multiple cylinder misfires??
Old Aug 7, 2012 | 10:53 AM
77Audi's Avatar
Multiple misfires.
Old Aug 7, 2012 | 01:42 PM
johnnyaudi's Avatar
Spark plugs & gapping , & does ur car have an icm, got intengineering icm delete & coils & all my misfires went away
Old Aug 7, 2012 | 01:46 PM
johnnyaudi's Avatar
Or just replace icm (ignition control module) got a ebay 1 for like $35,
Old Aug 7, 2012 | 05:20 PM
z28pete's Avatar
Originally Posted by 77Audi
Multiple misfires.
Multiple misfires are usually the result of a lean fuel mixture. You could check the fuel pressure with a gauge, and make sure the fuel filter is not clogged. Also check for active and stored trouble codes.
Old Aug 7, 2012 | 06:55 PM
ImTheDevil's Avatar
Yep, codes are the key. No ICM in a 30v V6. Cleaning the MAF may help too, depending on what codes you get.
Old Aug 10, 2012 | 01:18 AM
77Audi's Avatar
Thanks for all your replies, found out the fuel filter hasn't ever been changed, and cleaned MAF. Also was running low octane, after research found out compression is 10:3:1 on 87..... That would do it.
Might hit it with something to clean the carbon out from the low grade stuff, problem solved! Runs great!
Thanks again!
Old Aug 10, 2012 | 08:08 AM
jonbonesjones's Avatar
Moderator
Seafoam in the gas tank should clean it up.
gabiosz
Nov 15, 2011 05:13 AM
TomKat
Sep 18, 2011 03:09 PM
7808
Nov 20, 2010 03:40 PM
kraylon
Jul 29, 2009 12:19 AM
Barust
Mar 4, 2008 07:48 AM
