high beam problems
Old Oct 5, 2009 | 07:45 PM
stefan81's Avatar
Default high beam problems
i have a 2000 1.8t a4, my car fail inspection because high beam dosent work (flashing isnt working eather). fuses ok, bulbs ok. any ideeas?????thank you...
Old Oct 5, 2009 | 08:03 PM
Andrew149's Avatar
the cluster prob went bad
Old Oct 5, 2009 | 08:32 PM
ImTheDevil's Avatar
Combination switch is likely - they fail a lot, in a lot of ways. $158ish new and easy to install although you have to pull the airbag which makes some people nervous.
Old Oct 5, 2009 | 08:42 PM
kayakman13's Avatar
Just did this, and I'm working on a writeup. PM me with any questions. You shouldn't be nervous about the airbag. Disconnect the battery and lay on the horn. It shouldn't honk, but it'll be sure to help drain residual power. I let it sit an hour as well. No problemo.
Old Oct 5, 2009 | 08:53 PM
Andrew149's Avatar
lol i went to go repair mine and the screw on the steering wheel was striped
Old Oct 7, 2009 | 07:52 PM
stefan81's Avatar
thaks guys, i replace the combination switch. got high beam again
wsholar
Sep 12, 2013 06:20 PM
andrewsjr4
Mar 16, 2012 03:14 PM
corallini081
Oct 23, 2009 03:17 PM
erniepm
Nov 19, 2007 05:07 PM
dermguy
Mar 5, 2007 06:19 PM
