how do I check injector duty cycle with a multimeter?
Old Apr 22, 2011 | 05:38 PM
gregp1962's Avatar
Default how do I check injector duty cycle with a multimeter?
I want to measure the injector duty cycle using a multimeter. There are two wires into the injector. I would think that I should ground one wire of the multimeter and tap into one of the injector wires. But which wire do I tap into? Or, do I not ground the multimeter wire and tap into both injector wires? I don't have a VAG-COM
1997 2.8.
Old Apr 22, 2011 | 06:28 PM
MetalMan's Avatar
To check duty cycle, you need something that can measure time; a multimeter generally cannot do this. If you have an oscilloscope you can find out the duty cycle by measuring the time between open/closed. Best way is VAG-COM since you can get readings direct from the ECU, but maybe somebody can chime in with another alternative (I can't think of any).
Old Apr 22, 2011 | 06:37 PM
ImTheDevil's Avatar
Vagcom or a scope. A meter won't react quickly enough (you're talking milliseconds) to show you anything.
Old Apr 22, 2011 | 06:54 PM
gregp1962's Avatar
My multimeter has a duty cycle setting. I just need to know what wires to probe. There are two on the injectors.
Old Feb 29, 2016 | 07:02 PM
Michael Fischer's Avatar
Read this. Very helpful.
http://en-us.fluke.com/training/training-library/test-tools/digital-multimeters/how-to-measure-duty-cycle-with-a-digital-multimeter.html
Jayr1000
Feb 19, 2011 12:14 PM
a4sport
Sep 25, 2006 04:08 AM
OysterBay
Nov 6, 2005 06:50 PM
mig
Sep 25, 2005 11:35 PM
